flexplate
Old 09-19-2011, 10:06 PM
vegrantboy's Avatar
Default flexplate
OK so I'm using a 5.3l for a swap and just bought a stock flex plate for a 2001 ls1 Camaro. What's up with the weight on it?? Shouldn't it be neutral weight seeing it's and internally balanced motor?
Old 09-20-2011, 07:23 AM
Circle-D's Avatar
It should not have a weight. Sounds like you got the wrong one??
Chris
Old 09-20-2011, 11:18 AM
vegrantboy's Avatar
It's what the computer pulls up for a 2001 5.7 Camaro. I found it odd too but online it shows the pic with the weight on it too.
Old 09-20-2011, 04:24 PM
forcd ind's Avatar
is it the same crank bolt pattern, or diff
a buddy ordered one, came with the correct spacer, but a gen one flywheel
some co's seem to be lumping them in with gen 1's
