Well I finally caved in and did it....
Well I finally got a stall guys ended up picking one up from someone here locally slightly used for under 400 bucks. It's an fti billet 3600 with a 2.2 str so hopefully it will drive well on the street and put up some good numbers with my ls6 swap I've got all the bolt ons so I figured the stall is the only thing I've left out lol
You will not be disapointed in the fti converter. I really like mine. I have had it in about a week now. The lock up on it is harsh but hardly noticable now that I got lock up tuned out unless it's in OD.
thanks guys I was actually going to ask about that I heard fti converters tend to lock up a little harder because they have no springs inside them? I could be way off but I thought I remember reading that somewhere? The car is a DD so I just hope i Didnt go a little too far by getting a 3600 for everyday driving.
I drove mine home 400 miles after the install and have put 200 on it since daily driving it. With a tune it's like stock unless you get on it. I lost a little mileage though. Mainly because I can't resist the urge to floor it.
Thanks steve I think it wu be fine for the street.. Does anyone have any insight to the lack of springs for the lockup inside the fti? Not that it makes a difference I'm just curious. Also does anyone know what thread size the converter bolts are the fti doesn't have them and I'm not using the shitty factory bolts.
One other thing I recommend for guys with big converters in street rigs is to have the lock up tuned to occur somewhere in the 48 - 53 mph range depending on the combination. In my opinion it provides for much better overall driveability.
g
Honestly, I kinda hate my low 40s lockup. Even with 3.73s, when it locks at 42 or whatever it puts the motor at like 1500 rpms or so. And when you have a cam it's likely to have some bucking down there with a high load (overdrive gear). Remember, aftermarket cams are less efficient then stock cams in those low rpm regions. So keep that in mind as you are modding.
I like my FTI converter even though mine is a little 2800. Drives great. Lockup is good. I dont think its harsh at all when it locks up. Feels just right to be honest. I have my lockup set at 52mph. I hated having a stock lock up speed. In the city it would be locking and un locking all the time.
