newbie on stall converter
i was wondering wat rpm to stall the converter at the track??i got a pi 4000 stall.. dont know to much about stall converter wat would be great stalled so i get a good lounch at the track help plz thanks in advance.. mods 6.0 lq4,236/242 cam 862 ported heads milled.10, 3.73 gears and pi 4000 stall
You can buy a 2-step that'll give you a rev limiter when applying the footbrake. But for actual launching RPM, I'm not the one to give advice on that, you'll have to do passes with your set-up. I'm sure 5 guys here will give you 5 different opinions. Trial and error, is my advice. Play around with it.
It really is trial and error. I tried mine at 2500 and almost hit the wall, even ended up in the other lane for a second. I almost **** my pants. At about 1200 I can do a 2.0-2.1 60', and at around 1700 it ***** and gets. 1.9 60'. It took me about 6-8 passes to dial in my best launch rpm.
