4L80E - no movement, no line pressure... Ideas?
So I finally finish up my conversion build, get things dialed in, car is running great... I did notice a couple of times that once everything was up to temp - shifting in and out of gear (fwd gears or reverse) it would slide into gear slowly. Sometimes requiring a quick rev to get it to engage. Very similar feeling to being low on trans fluid where the pump/converter is starving for fluid.
This is a bone stock early 4L80E with newer wiring harness conversion. T42 controller, stock converter (freaking huge beast that kills any performance you can think of)... anyways, it did run great. Shifts on the spot, lockup was perfect. No complaints.
Well after some easy tuning I pull over to make some IFR changes, load the tune, crank her up... and no go. No nothing! Even at a high rev.. (fluid level was fine)
After some quick diagnosis, I have ZERO line pressure.
I pulled the trans pan, nothing obvious that could be wrong - fluid seems normal. I drop the trans, pull the pump and the only thing I could notice was some pump wear. I know its not good but I cant imagine loosing all pressure.
Thoughts? Ideas?
See attached for a pic of the pump...
Thanks all!
David
Thoughts? Ideas?
Thanks all!
David
LOL, c'mon.. she's good for another 100K
I know its trashed but wouldnt that generate at least a little bit of pressure?
Another thing I forgot to mention was that I have always had a vibration when the converter is bolted up to the flexplate and it gets worse at higher rpm (in park/neutral). I have the correct flexplate with the crank spacer but cannot get rid of the vibration. I have tried several times to realign and space the converter properly. Yes, the converter was seated properly and has plenty of engagement. I also think the pump bushings are worn because the converter seemed to have a lot of play/wobble when you slide it into the pump.
So I certainly need a new pump... any other suggestions I should check?
Thanks!
David
Thanks!
David
