96 4L60E behind LQ4
Moderator
No the input will not work with what you are trying to do. The issue is that the later LS1 units (98^) used a deeper bell, longer stator tube and also the input shaft you mentioned. You can use what you have. However you will have to get a custom converter with longer pilot or get an adapter to make the pilot longer. HTH Vince
