AOD to LY6?
Old 10-20-2011, 06:41 AM
bitterman's Avatar
Default AOD to LY6?
Hi,
I am looking at overdrive transmissions for my 68 Chevy II Nova project. It has 4.10 out back, I'd like to go wit about a 3500RPM stall also.
4l60E is out as I want more reliability.
4l80E full manual is a posibility but I am worried about trans tunnel fitment in the Nova, I also don't like how much extra power it uses.
Lentech is really close to me and they make a really strong product and take care of the local racers really well so I am tempted to go this way.
Pros
-.67 overdrive gear for the aod over .75
-no shipping
-less power loss I believe
-smaller and lighter then the 4l80s
-Overdrive is locked out till you flip a switch so not breakage unless I'm stupid
-Great warrentee
-Local to me so if any problems arise they are right here to help me.
Cons
-Its a ford tranz ;(
-Have to go with aftermarket SFI bell housing. about $700 to the price
-Throttle cable linkage for cable to control trans pressure
-What flexplate for torque converter?
-What tranz spacer?
Has anyone put an AOD behind a LSx engine? Details would be great!
Thanks,
Bruce
Old 10-21-2011, 12:16 PM
bitterman's Avatar
Nobody?
Old 10-21-2011, 01:24 PM
1lejohn's Avatar
By the time you buy all the parts to make the AOD fit you could have built a 60e that would work IMOP. The 60e can be programmed to do what ever you want.
Old 10-21-2011, 02:39 PM
Restricted User
98Z28CobraKiller's Avatar
Ford guys use GM transmissions for a reason.
