Just finished dealing with Jakes Performance
So I got one of Jakes th400 rebuild kits, and a 3600 stall.
It took a little longer rebuilding the th400 since it was the 1st one, but when there were questions Jakes answered them.
Finally drove the car today and was very impressed the thing shift nice and all the tricks on Jakes webpage on building the th400 worked for holding the shifts and stuff.
Great company to work with and great support.
This tranny is behind a 408 iron ls putting down about 500 to the wheels in a 85 mustang and the car can be dd.
When talking with Jake I told him my setup. I went with his standard rebuild kit. With a new smooth race drum.
For reference on rebuilding there is a pretty good DVD you can buy on e-bay, the go fast mods on Jakes page, and
How to Work with and Modify the Turbo Hydra-Matic 400 Transmission (Motorbooks Workshop) NOTE*this book is out of print I found a copy at a library and to make sure I did not damage the original made copies of the rebuild pages*
There are specialty tools you need that will run you about $400 to do the job, but I found a place to buy em.
A lot of the special are not needed. You need a device to compress the springs which can be made out of some threaded rod and some flat bar. I have done many trannies and never bought a special tool. The 400 is a good trans to rebuild and learn the basics. My first was a th350, then th400 then some glides and 4l60e's. Just take them apart and line the parts on a workbench. Then pull apart and rebuild each part then put it back together before you move on to the next. Plus the books are helpful and can show you where things go if you forget.
Jake is not only a great dealer, and a great mechanic, but his customer service is second to none. I had a problem about a month after I got my valve body and transbrake from him and I wasn't available when jake was and vice versa. Left his personal cell number for me to call him and not only talked about my problems, but talked cars and tranny tips and tricks and some insider secrets also for several hours.
Great guy and even better support, jake your what a real business should be!
I completely disagree with this thread in every way, shape and form. Jake was absolutely horrible to deal with. He's a dishonest scammer and unfriendly. He scammed me out of a $3,000 transmission. I opened up the transmission upon receiving it and the filter was ALREADY clogged. He blamed it on my wiring harness, but this transmission was not even installed on the vehicle yet. The transmission was squealing from mile 1. Jake offered no warranty services and did not offer to help in any way. This was a bitter lesson learned. I don't give a **** if he is a vendor on here or not. This was my experience and it is 100% factual. I have no skin in this game and no reason to lie. I hope others don't make the same mistake I did by deciding to purchase a transmission from these dishonest scammers.
I looked this customer up today because I had doubted it was even a legitimate customer.
Bought a transmission in 2013, no phone calls this year at all from the number on file.
I've warrantied transmissions that were years out of warranty if we found a build issue or even questionable as to cause.
LS1Tech Administrator
Received 1,484 Likes
2011 has been over for quite a while, not sure why this was revived for an entirely separate incident.
