A4 swap ?s
A4 swap ?s
Well to start off. This is a 2002 formy orig banger car. I bought it half *** swapped. I was reading through the big post and was still slightly confused on some things. With the Pnp switch how do I wire the reverse lights. There are just 2 wires under the dash labeled rev lights not tied to anything. Also the switch on the trans is the neutral saftey/prndl correct? Lastly how can I hook up a shift interlock the right way? I have the a4 engine harness already. Thanks for any help!
