Delayed 2-3 upshift?
Old 11-11-2011, 11:27 AM
00pooterSS's Avatar
Default Delayed 2-3 upshift?
I was starting to notice that as my car got hotter especially when at the track the 2-3 upshift..shift.. would not happen at the shift point and it would bang off the revlimiter then shift. It wasn't a problem for a long time and it had been tuned for a long time. Once it cooled down a bit it would nail the 2-3 shift just fine.
I also noticed sometimes it would engage 3rd a little slow and sometimes cause the trans to slip a little when 3rd engaged.
Now my 3rd and 4th gear clutches went out so I need to have the trans fixed or I may just replace clutches..
Here is my question though What would cause this so that I make sure that is addressed and it doesn't burn up the new clutches when I do repair the transmission?
sorry if there is an easy answer in a search, I didn't find what I was looking for.
Old 11-11-2011, 03:00 PM
1lejohn's Avatar
The rebuilt tranny will most likely fix your problem. if it continues then you might have to upgrade to a vacuum controled shift. We had problems with several name built trans that wouldn't shift from the 1-2 and sometimes on the 2-3. I had Rossler put in the vacuum mod and it shifts every time on time at the correct rpm.
Old 11-11-2011, 03:10 PM
projectX's Avatar
^ I agree
Old 11-11-2011, 03:14 PM
00pooterSS's Avatar
I spoke with one builder that does the vacuum modulator, all the others that I have looked into seem to not do the vacuum modulator. I was curious what the reason is for staying away from it...
Old 11-11-2011, 10:35 PM
01ssreda4's Avatar
Upgraded clutch pack, Trans-go HD2, and a good trans tune will do wonders.
Old 11-12-2011, 01:57 PM
pancho toco loco's Avatar
If you had the shifter in the 3rd position that will engage the over run clutches. When the trans is sent the signal to command a 2-3 shift there is a delay in the arrival of fluild from having the over run clutches engaged.
Old 11-12-2011, 05:54 PM
Gingervitis Addict
slow67's Avatar
X2. In stock form, the over-runs only come in in manual 3rd, during the 2-3 shift requiring additional fluid.
Old 11-13-2011, 03:39 PM
00pooterSS's Avatar
I don't know anything about how automatics work so I don't really know what the over run clutches are or what their function is, I will try to do some research to figure out how they work/what their function is. But apparently I need to leave it in D instead of 3.
Old 11-13-2011, 03:41 PM
00pooterSS's Avatar
I've half considered doing the clutches myself. I have rebuilt everything but transmissions before so i'm still a little unsure of cracking open an auto.
Quick Reply: Delayed 2-3 upshift?
