lq4 backed by a 4l60e
Old 11-21-2011, 01:02 PM
82lsx cutlass's Avatar
Default lq4 backed by a 4l60e
I wanted to know if anybody's use 4l60e with a lq4. I just had a 60e rebuilt with 5 pinion planetaries. Will it hold?
Old 11-21-2011, 02:52 PM
74novacustom's Avatar
Ive got a 4L60e behind an LQ9.
I spent 300 on the trans to buy it.
I spent 1500 on a performance build on it.
less then 3000 miles on it with mostly freeway driving and no track time i broke the input shaft and drum.
I would suggest a hardened input shaft and drum, they are around 420.00.
if you plan on nitrous or slicks also plan on a hardened output shaft.
Or a factory 4L80E...
Im stubborn and am still using my 4L60E. If it goes out again it will get an 80E/
Old 11-21-2011, 02:58 PM
Yea all the trans builders I call all say the same **** get and 80e and be done with it.
Old 11-22-2011, 11:02 AM
Well my buddy said he put a corvette input shaft in vette servos and a .500 boost valve and shift kit. And gm 5 pinion planets. The only thing I seen was that he did use the 29 element sprag I hope it holds!
Old 11-22-2011, 11:09 AM
I meant he didn't use the better sprag
