b&m pro shift or hurst quarter stick kit for my 4l80e chevelle?
i was wondering if there is any 4l80e specific kit for my 4l80e transmission... does anyone have part numbers?
do i have to order it for a different transmission(didnt see any listed for the 4l80e) if so which one?
will i need to buy extra parts to get it to work... if so which ones.(which of the two kits comes better suited for the 4l80e)
thanks everyone. ive been searching since the morning, it means alot.
i have used a couple of the B & M Pro rachets on them, work fine-you have to rem a pin, and use the correct hole in the trans arm, along with installing the shift cable correctly on the shifter housing
the shift cable can go inside/outside the shifter housing, if wrong it throws everything off, fixed a few with that problem, lol
i think they dont really list them for 4L80E's, just 4L60E's, they just havent updated lit.
Use the QuarterStick or ProShift for the 700R4 application, which is the 3160030 model number. Sometimes shown as 316-0030 too.
It's also an A4 style transmission & people in the F-Body world do use them for the 4L60E/4L80E platform.
Thanks that's exactly what I was looking for. It looks like that part number/every 700r4 hurst quarter stick is on backorder. I'll be going with the b&m and using the 700r4 gate plate.
Sorry I don't go on here much and I hope its not too late but here's the link http://www.wideopendesign.com/Produc...s-Shifter.aspx also I hope the pro shift is different than that pro rachet because I had a prorachet with the 700r4 gate in my jeep before the winters and it would shift like ****.
