will a 4l60e fit an LT?
Old 11-28-2011, 05:47 PM
svg210's Avatar
Default will a 4l60e fit an LT?
Hey guys can anyone provide me with info on wether an 4l60e fit an LT vette? Thanks in advance!
Old 11-28-2011, 06:22 PM
Moderator
Vince B's Avatar
I'm sure both the 700r4 and the 4l60E were both in the C4 body vet's. I'm kind of confused on your question. I will say that with both transmissions in that car they did use a unique transmission case. If memory serves me correct it has a "V" or a "Y" on the bell housing. The inspection cover is a little different on these units and also the rear of the case is a little different as well. It requires a different tail housing for the torque arm as well. I'm sure a non vet case could be fabricated but the tail housing is the key for one of these units. I have two of them that I snatched off of Ebay if you need one. Just let me know. HTH Vince
Old 11-30-2011, 07:30 PM
svg210's Avatar
Thank you for your input! The guy decided to rebuild it.
