PY3600E and TransGo install questions
I am buying a PY3600E converter and have a few questions before I install it.
First off, do you have to drill holes in the flywheel inorder to use all 6 mounting lugs? Should I do this or would 3 be enough?
Next, should I install a TransGo at the same time? I want the tranny to hold up as long as possible and don't know if I should do a shift kit or not.
Thanks,
Chris
Thanks,
Chris
the 3 holes are enough, but If you want you can use your stock flexplate and drill the remaining 3 holes. Another option is TCI sells a 6-bolt SFI approved flexplate
