EPC solenoid
Old 11-30-2011, 10:35 AM
SixShooter1125's Avatar
Default EPC solenoid
Anybody know how to replace the EPC solenoid? Do I need to drop the valve body, i dropped the pan last friday, but i did not even look at it. Any suggestions?
Sorry, this is in a 4l60e
Old 12-01-2011, 06:27 AM
Moderator
Vince B's Avatar
No you do not have to drop the valve body. You will need to remove the 1-2 accumulator housing to get it to slide out of the valve body. Make sure to look at your old one closely before removing the retainer bracket.It will be set in a specific position and you need to make sure to do this when you reinstall the new one. HTH Vince
Old 12-01-2011, 10:06 AM
Well, since i will have to remove the housing, might as well change the piston and spring in the 1-2 accumulator. Any tips on doing this or is it as simple as it seems. Drop cover, pull piston and springs replace and put the cover back on?
Old 12-01-2011, 05:44 PM
Moderator
Vince B's Avatar
Yeah its all pretty simple IMO. You might want to use some compressed air to pop the piston out of the housing by just blowing a little air into the feed hole. HTH Vince
Quick Reply: EPC solenoid
