A4 question
The only difference between a 60e and a 65e are the planetary gear sets. That's it. A 65e is stronger physically.
But, because they both share the same hydraulics you'll need to have a nice unit built to be able to handle the increased power of your combination not to mention the higher stalling converter. A stock unit will let you down in short order depending on your driving habits.
Yes, an '01 unit will fit in your car.
Feel free to give me a call if you'd like to discuss it in detail.
g
g
WOW this is an old thread. What i have been told is that To use the corvette trans I would need to replace the bell housing and the linkage for the shifter that goes thru the transmission and the tail housing. the reason i was asking was that i had a lead on a Corvette trans for cheap.
