Stall Heat
Stall Heat
Will there be a lot of difference between a 3500-4000 stall temp?Ive just hurt my 4l60e and going in for a rebuild and doing a stall at the same time.So will the bigger stall produce a lot more heat?i have 3.9 rear.
Is it worth while running a fan on the cooler with a thermatic temp switch and set it at 185 degrees or even wire it into the factory fans so when they turn on it turns the fan on for the trans cooler?just a thought
Moderator
Efficiency is the big deal, and higher stall speeds tend
to be less efficient. But there's a lot of room between
best and worst, a poor 3500 could throw more heat
than a nicely efficient 4000.
I had built up a cooler with thermostats and muffin fans
but since I run full time fans anyway, the "dope style"
larger Hayden is doing fine and I never swapped. I used
a Selco thermostat I got from Digi-Key, they have them
in 5C increments.
You don't want to overcool because it inhibits converter
lockup. Usually not a problem down here but the other
week it was near freezing and noticeable for several miles.
in 5C increments.
