Problem with the converter being to tight in the crankshaft.
I mated my powerglide with my motor and installed it a few weeks ago, and i had no problems with the mate, or anything. But now that i am about to bolt the converter to the flywheel it seems that the converter nose is really really tight in the crankshaft. It will spin slightly, but not move forwards and backwards.
Would there be any real downside to just putting a spacer in and bolting it up as it sits fully seated in the transmission?
The converter is perfectly straight, and brand new.
had exactly the same problem with my th350 i have an 8 inch tci tc in mine and the problem was the pilot it had an extention press fitted on it which i never noticed i thought it was part of the tc wasnt till i looked at another converter
Moderator
^Good move! Inspect the pilot and also the snout of the converter for burs. If all looks well I would test fit the converter to the flexplate/engine to see it there is an issue with the pilot being to long or like said if its not the correct size. Like Chris said converter spacing is very important. Let us know what you find.
