97 m6 to 01 ls1 4l60e ???
Your car is a 97, and the donor car is an 01? I'm not sure if the tranny crossmembers are different between the 97 V6 and V8, but I had a m5 V6 before I did my swap and I used my stock 97 V6 cross-member. I just lengthened the hole for the tranny bolt. It barely makes it, but it does.
Try either drilling out/lengthening the hole in a 97 crossmember, or do what another member did on here and weld a piece of 1/4" to your stock crossmember, and then drill a hole in that for the tranny bolt.
4l60e, 97, alabama, bfgoodrich, crossmember, fbody, late, ls1, m5, m6, montgomery, radial, shift, ta, transmission
