Trans Fluid Recommendation
Old 02-04-2012, 11:37 AM
Turbo 6.0's Avatar
Default Trans Fluid Recommendation
I am going to be installing a deep trans pan and was just wondering what trans fluid you guys recommend. Vehicle makes about 600rwhp and has a "built" 4L65 w/ redline clutches & protorque converter.
Any suggestions would be helpful!
Old 02-04-2012, 05:53 PM
Turbo 6.0's Avatar
No recommendations?
More info needed?
Old 02-04-2012, 07:02 PM
sjsingle1's Avatar
yours is a commonly asked question...........and the common answers are........dex 3.....or dex 6.........some converter manufactures do not recommend synthetics......i run dex 6 and a truck pan and am happy with it
Old 02-04-2012, 07:39 PM
senicalj4579's Avatar
dex 6 with my ss3600 stall here
Old 02-04-2012, 08:03 PM
Leeroyws6's Avatar
just make sure its red.
Old 02-05-2012, 09:45 PM
Turbo 6.0's Avatar
Thanks for the replies so far......
Any of you guys using any additives?
How much fluid does a 4l65E with a 10" converter typically hold?
Old 02-06-2012, 07:47 AM
Moter's Avatar
From Yanks site "Add one qt. Oil prior to installation of converter. We recommend a good name brand ATF in either a Dextron III or a Type F (We do not recommend any type of Synthetic fluid at all.) Dextron 6 is ok."
Old 02-06-2012, 09:55 AM
badblazeSS's Avatar
lucas
