Gear noise in trans
Gear noise in trans
Ok put a 4l80e in and it's almost full if not full of fluid. When I rev it in park I here like a gear noise the goes high when revs go higher. Doesn't sound normal. Was wondering what it could be.
Also I had to cut and splice the trans harness and there where 2 wire that were the same color yellow with black strip. Anyway to check all the wire to make sure there hooked up right?
