Cheat Sheet for TH400 Drive Gears?
I have a TH400 out of an '89 G20 Chevy van that had the 5.7L engine.
I've seen all the calculators online (messed with TCI's already). My tire height is 28" & the gear ratio is 3.42. I'd like to get a driven gear so my speedometer will be correct, but I have no idea what drive gear I have. The transmission is already in the car, so I was hoping for a "cheat sheet" somewhere that might list the drive gears used in a particular vehicle. Does one exist or do I need to crawl under the car?
Thanks for any help!
Scott
Scott
The formula is the axle ratio(3.42) x the number of teeth on the drive gear(15 is common) divided by the tire diameter(28")x 20.2.So 3.42 x15 divided by 28x20.2 +# of tooth on the driven gear.
