Turbo 400 Trans Cooler Install Questions
Old 02-18-2012, 05:51 PM
StraightTimeStirrups's Avatar
Default Turbo 400 Trans Cooler Install Questions
I converted my M6 LT1 T/A to a TH400 RMVB Trans-Brake car. My questions involve ins tally a Trans Cooler in front of the Condensor in front of the radiator.
1) What type of fitting is used to connect the lines at the tranny (I have the stock fittings coming out of the tranny now and not sure what type of fitting to buy to connect my lines to it. (NPT, PIPE etc.).
2) How did you route your lines to get to the front of the radiator from the Turbo 400?
3) Did you run hoses the whole way or did you use hard lines?
Thanks!
Joe
Quick Reply: Turbo 400 Trans Cooler Install Questions
