Converter
Old 02-26-2012, 08:11 AM
cajunss's Avatar
Default Converter
Will be doing a cam swap soon and was wondering what Converter do you guys run? Pro and cons between each brand etc?
Old 02-26-2012, 08:35 AM
black00ssFL's Avatar
3 min search yielded these results:
https://ls1tech.com/forums/automatic...ter-brand.html
https://ls1tech.com/forums/automatic...uld-i-get.html
https://ls1tech.com/forums/automatic...ions-only.html
https://ls1tech.com/forums/automatic...converter.html
https://ls1tech.com/forums/automatic...ut-revmax.html
Old 02-29-2012, 01:00 PM
cajunss's Avatar
Thanks but wanted some updated info.
Old 02-29-2012, 05:04 PM
cajunss's Avatar
thinking about going with a Circle D or a Yank.
Old 02-29-2012, 05:11 PM
00pooterSS's Avatar
Both brands are excellent.
I have had 2 Yank converters and both have been awesome. One of those two is currently in my car.
I had a PYE3400 but I wasn't making enough power to use that converter so I sold it to a guy that had a turbo full size truck and it worked great for him.
I now have a SS3800 and it is a blast. If you are doing a mild-wild cam and street drive the car you are going to want a 3600-4000 stall.
It will feel weird at first, then you will nail the throttle and blow the tires off the car and wonder why you didn't put a big stall in it sooner.
My car has had a bigger stall in it for 4 years and still has the stock cam....
Old 02-29-2012, 05:20 PM
LS1121's Avatar
Get a RevMax, just as good but much cheaper. Call them with the info on your car and they can suggest what might be Best for your needs.
Old 02-29-2012, 06:42 PM
ls1wallen's Avatar
I have a revmax 4100
