Wont go into gear, Please Help!
Old 03-12-2012, 08:50 AM
LS1MUNN's Avatar
Default Wont go into gear, Please Help!
I finished my engine swap now only to find that the trans that was working fine now wont go into any gear at all. Move the shifter and it seems to do nothing. No reverse or forward gears. I have double and triple checked the linkage and there is plenty of fluid in the trans. The T/C is bolted up, all electronic connections are good but the thing wont move Anyone have any ideas?
Old 03-12-2012, 09:14 AM
Jeremy@RPMTransmissions's Avatar
Did you make 100% sure you got the torque converter fully seated in the pump? If not you might have broken the pump rotor causing no pressure. You might want to pull a cooler line off the radiator and put it in a container then crank the engine over to make sure it is making pressure.
