400 turbo speedo
400 turbo speedo
I put a 400 turbo in my trans am and i dont no what to do with speedo. Does anyone have any idea what i need to buy or do to hook up speedo. thanks for any info.
The reluctor and speed sensor can be purchased from PATC Transmissions. Yes, you just replace your factory speed sensor plug with the new one. If your car was originally equipped with a 4L60E then the speedometer will work with no tuning. If your car was originally equipped with a T56 then you will need to have the PCM calibrated in order for the speedometer to read correctly.
Y Do you know if that one also works with the th350?
GM8655291(sensor)
GM8655315(Drive sensor rotor)
you will also need to get the plug for the wiring, i got mine at NAPA for $18
You have a 400 right?
right mine is a 400, thank you for the PN's, could stock from sensor and reluctor from 4L60 be modify to match in the 400?
