trans cooler install pics
Old 03-18-2012, 06:39 PM
1sicklsx's Avatar
Default trans cooler install pics
I'm looking for ideas on where/how to mount my trans cooler and pics would definitely help me out! So let's see your install pics!
Old 03-20-2012, 08:49 AM
SSHAWK's Avatar
I will post up some pictures tonight for you..
Old 03-20-2012, 09:36 AM
Blue85350's Avatar
https://ls1tech.com/forums/automatic...e-install.html
The one in link is a member "drone", I pretty much did the exact same thing. I even used his parts list to order for my setup.
Old 03-20-2012, 10:23 AM
Moderator
jimmyblue's Avatar
Mine, used a piece of snap-in shelving support for the
struts.
Attached Thumbnails trans cooler install pics-transcoolerdopestyle20100523_50-.jpg
Old 03-20-2012, 11:16 AM
Sy99T/A's Avatar
I put mine inside the fenderwell on the passenger side air flows through the hole in bumper and I cut a hole in the back of fender well liner for continuous airflow through area. inside the fenderwell area there were already holes available to install mounting bolts
[IMG][/IMG][IMG][/IMG][IMG][/IMG]
Old 03-20-2012, 11:50 AM
SSCAMARO02LS1's Avatar
Good stuff 85350, and yes you are correct by saying " you get what you pay for "
definitely go with Strong / quality braided lines.
Thanks and have a good day.
Old 03-20-2012, 01:32 PM
DopeFedZ's Avatar
I moved mine back up to the front and mounted in front of the radiator. Drove it around this past weekend and saw nothing higher than 145* for the trans and 185* for the coolant. I have a fan on the cooler just in case and my front bumper plate area is cut out.
Quick Reply: trans cooler install pics
