How to identify 4l80e
Old 03-21-2012, 02:22 PM
98LS1driver's Avatar
Default How to identify 4l80e
Looking to swap my 02 TA over to 4l80e when the 60 goes. What all is needed and what is the best way to identify a 80e? Plan on going to junkyard and pulling one and getting it rebuilt before going in. Or would it be better to just build the 60e and go with it??
Old 03-21-2012, 02:33 PM
Jeremy@RPMTransmissions's Avatar
How much power is your car making?
4L80e transmissions are pretty easy to identify. They have 2 speed sensors on the driver side of the transmission. The early units have no top bolt hole in the bellhousing so you loose 2 bolt locations. The early units also have the cooler lines together near the front of the bellhousing area. Late 4L80e transmissions have an upper bolt hole and the cooler lones are seperated on the passenger side of the transmission about 10-12" apart. Here are a few pictures.
A 4L80e compaired to an LT1 F-body style 4L60e
This is a picture of an early 4L80e
Here is a late 4L80e
Old 03-21-2012, 03:16 PM
It's basic bolt on car at the moment 200 spray on dr no stall
Old 03-21-2012, 03:17 PM
What would u recommend ? Plan on going stall with 228r
Old 03-21-2012, 03:21 PM
I wouldn't go through all the trouble putting a 4L80e in the car. One of our Level 5 4L60e builds will be perfect for what you are doing.
Old 03-21-2012, 04:15 PM
k im going over to your website now to check you guys out. I have a revmax 3600 as well waiting to be put in now or should i go 3200
Old 03-21-2012, 04:29 PM
Good deal. Let me know if you have any questions about anything.
If the revmax 3600 is built for nitrous I would use it. If it isn't, with that big of a shot you might blow right through it.
Old 03-21-2012, 07:25 PM
It has the nitrous balloon plate so I'll use it
Old 03-21-2012, 08:53 PM
Yea it should be fine then.
Quick Reply: How to identify 4l80e
