Help P0758
Help P0758
Car drove fine last night, when to start it up this morning and go to the store and 3 blocks down i car stops shifting and stalls itsself up. I get the car home and i barely had enough power to pull up the driveway. I let the car sit for an hour while i looked up what could be wrong with it. I go back outside and erase the code to see if i set just this one again and not everything is running fine, not stalling and shifting normal on its own and when i manually shift it. Could the pcm made a mistake and forced the car into limp mode or am i looking at an actual problem?
been searching a ton of treads about this and some point to just the solenoid being back to the pcm being bad or warm clutches, trans never slipped before this/ stalled before this?
4l60e with around 110k miles on it and 2800 stall
once again tonight right after start up the car stops shifting and stalls itsself up and throws the same code.. I used my scan tool once again to delete the code and the car runs fine after that. Anyone have any idea what could be causing this problem or have something like this happen, im lost
