Is this right??
Is this right??
Lets see if I can explain this....car has external trans cooler. One coolant line runs to top of radiator, other coolant line runs to one side of external cooler, then there's a line that runs between other side of external cooler to bottom of radiator......is this right????
nope, leave the bottom line on the BOTTOM of radiator as is, come put of top radiator go into ex cooler then back to trans or bypass the radiator complety. IF your ex cooler is mounted with both lines pointing side ways go into the botton line and out the top. if you wish you may mount the cooler with both down will not matter which is in/out.
I would not mount the ex cdooler with both line up
Johnny
Johnny
Johnny
