4l80 to buy or not???
Im looking at a used unit out of a 2500hd truck thats a 1997 model. It still works except it slips in reverse only and all other gears work fine. He wants $75 to cover what the trans shop will give him for a core charge. The trans is already been taken out this weekend and ready to buy. My ? is, would this be a good price? Thanks.
thanks, I have what I believe to be a stock high mile 60e and Im curious if an 80 is really necessary for my power level in sig? The current trans does great so far and shifts nice and firm but that will only last so long as it currently has 195k on it and I have owned the car since it had 120k. I am also wondering what kind of $ this kind of swap is gonna take with TQ arm, corss member, converter, cooler, tune, harness, lines, ect??? I have been reading but am still unsure if this swap is for me, as I dont go to the track much and I know better than running my current trans through 3rd into OD @ wot. This is my main intrest in doing this swap so I dont have to worry about overpowering OD clutches. Any advice? Im also considering swaping my high mile stock engine for a stock 6.0 with some kind of cam and maybe a small (75-100) shot to boot and go from there.
If you sold your original 60e, converter and such that came out of the car for a swap, you would recoup a decent portion on any financial loss you incurred for the swap.
I'm a builder for one of the sponsors on here and I will say, yes, at 450 hp it is most likely overkill, but if you plan on making much more power it is most definitely a viable option to look into. A built 4L60E will cost you a lot more money than a 4L80E swap would, and many people on here make the 80 swap out to be a very difficult, time consuming swap and make it sound like the entire trans tunnel needs to be hammered to hell to make it fit, when really it's just a quick and easy portion. A new flex plate, cross member, yoke and converter, and you have yourself a 4L80E, which stock for stock is a MUCH stronger transmission then the 4L60E. I'd put it up against many semi-built 60's as well.
