5.3 4l60e 4l80e swap
Old 04-04-2012, 09:55 AM
deuceswildpacefl's Avatar
Default 5.3 4l60e 4l80e swap
I just pulled the 5.3 4l60e out of my 37 ford coupe and want to put it into my 67 chevy pu with a 4l80e I am running into a problem with the converter to flywheel according to genstar transmission there is a stock gm flywheel that comes with a spacer and bolts to do this swap but no one at gm knows anything about it has anyone here heard about this or know the part no
Old 04-04-2012, 10:03 AM
black00ssFL's Avatar
Should be the standard flywheel package for a late model truck that has a 4l80e. I don't have the part numbers off hand, but a quick search in this section of the forum should get ya one real quick.
Old 04-04-2012, 10:16 AM
thanks I have been searching this forum and havent found it yet I was given a part number by gen star they said it would be a flywheel with spacer and bolts but when I ordered it from gm all i got was a flywheel
Old 04-04-2012, 11:00 AM
Ya, I think I remember reading that the kit is no longer available and you'd have to buy the parts separate. I bought mine used from a member here for my swap. A competent parts guy at a GM dealership should be able to find the part numbers.
Old 04-04-2012, 01:04 PM
thanks the parts guys here are nt competent they tell me you cant put a 4l80e behind the ls1 motor
Old 04-04-2012, 01:58 PM
finally tracked down the parts numbers for the flexplate and spacer
the flexplate part number is 12621399
the spacer is part number 12563532
the bolt part number is 12563533 quatity 6
this use to be all in one kit for $60 now the flex plate is $6o and the spacer is $54 and dont know how much the bolts are
Quick Reply: 5.3 4l60e 4l80e swap
