4L60E Shift kit
4L60E Shift kit
i was wondering which shift kit would be better the transgo HD2 http://www.summitracing.com/parts/TRG-4L60E-HD2/ or the e-3 http://www.summitracing.com/parts/TRG-4L60E-3/?
i tried doing some research but i wasnt able to find much info on the e-3
The -3 is a "full manual" kit that also uses a vacuum modulator. I do not recommend this kit for the street, unless you have built the unit to handle more horsepower from the start. The HD2 is much better for a stock unit. I offer a modified HD2 kit that will give you smooth part throttle shifts and quicker WOT shifts than the standard HD2, along with other updates such as Viton D-rings for the Corvette servo, Torlon checkballs, EPC solenoid filter, & more if needed.
HD2 seems to be the go to shift kit for these trannies from what I've seen. My built unit has one as do most others. Some builders will modify the HD2 some but generally agree it's a good kit for the money.
Holds 1st, 2nd, and 3rd to any speed. Backshifts to 3rd, 2nd and 1st by moving the lever. 1998 and up, if vehicle has torque management this kit will not make hard shifts.
If you move it to 3 it goes to 3rd and holds that to any speed.
If you move it to 2 it goes to 2nd and holds that to any speed.
If you move it to 1 goes to 1st and holds that to any speed.
So what benefit does this actually do in terms of how the transmission holds the gears as selected by the shifter?
No the stock trans cannot hold/shift to any gears at any speed.
My 65E holds any gear as long as the shifter is in that # and will downshift to that gear no matter what speed (tuned of course). I've bounced off the revlimiter in 1st because I forgot to move it to 2
We useTransgo kits,sonnax and superior shift kits in our recipe depending on the application.
We build bulletproof transmissions! It is critical that we know how you are running your vehicle and the needs you have for your application. If you're running nitrous, superchargers or turbo-chargers, please be sure to give us this information. We cannot setup the right transmission for your application without this information.
Please contact me for a professional consultation regarding your needs. We are happy to provide you with references both here in the United States and Internationally. Be sure to check out our website at maddogtransmissions.com
Hear what our customers and fans say on our Facebook Page at www.facebook.com/maddogtransmissions
We also accept orders over the phone. Be sure to contact us and we will recommend the correct transmission for your application. For your convenience, we accept PayPal and all major credit and debit cards.
If you prefer, we can call you personally, just e-mail us your phone number.
All our transmissions are very strong and reliable, and can be used for everyday driving. Extended warranties are also available.
Thank You,
"Mad Dog" Lou
Mad Dog Transmissions
Phone 770-781-0949
Fax 770-781-0969
Web: www.maddogtransmissions.com
Facebook: www.facebook.com/maddogtransmissions
Twitter: www.twitter.com/maddoglou
YouTube: www.youtube.com/maddogtransmissions
Thank You,
"Mad Dog" Lou
Phone 770-781-0949
Fax 770-781-0969
WHAT!!! That really answered the question. If your transmission will go back to first at any speed, and you do not have the "manual one valve" from TransGo, then somehow the factory "manual one valve" is not working as it should. GM has a built in "fail safe" in all of their transmissions that does not allow for "back to first at higher speeds", or the ability to hold first gear to higher or slightly higher than the WOT shift point. Second and third gears do not have the "fail safe" feature. GM could have done something different here, and since I cannot see the "manual one valve" in your valve body or other possible changes in the valve body, I can't state for sure that GM has the "fail safe" setup in your transmission. I have never seen a GM unit without this "fail safe", but there are always exceptions.
