Do I need a re-tune?
Had my dyno tune at lethal in SA a while back. Soon after my trans went out.
So I got a built 4l60E with a 3800 stall goin In over the weekend, and wanted to know if this will require a retune, or is it fine to run like this?
Im planning on running pretty soon at an event in my area...
Thx in advance.
Thx in advance.
I would get it tuned, because that way you can have the shift points adjusted, line pressure, etc., it will definitely maximize your gains. I wouldn't romp on it too hard either if you don't plan on getting it tuned because I've heard that can send the transmission into limp mode pretty much.
