4l60e 2-3 flaring - LS1TECH
Automatic Transmission 4L60E | 4L80E | TH350 | TH400 | TH2004R | Powerglide | Converters | Shift Kits
4l60e 2-3 flaring
Thread Tools Search this Thread
Old 04-24-2012, 07:52 PM   #1
TZ2884's Avatar
Default 4l60e 2-3 flaring
I've noticed some flaring between 2 and 3 at WOT. It doesn't happen during normal driving. Is there anything I should try or should I just go ahead and plan on having it rebuilt? it was rebuilt a little over a year ago before it was put into my regal along with a 5.3. I've heard things like maybe a bad computer, sicking solenoid, dirty MAF, and bad manual lever position sensor? Should I even look into any of those as a possibility?
I've considered a 4l80 swap but would much rather stick with the 60 if it can be built to hold up.
TZ2884 is offline   Reply With Quote
Old 04-25-2012, 04:50 PM   #2
TZ2884's Avatar
Any opinions?
Old 04-25-2012, 08:21 PM   #3
TZ2884's Avatar
Tried cleaning the MAF, but no change.
Old 04-25-2012, 10:56 PM   #4
JUNK's Avatar
if it's ready to go south on u, the flare will turn to neutral and u will know soon enough. There are a number of things that can be done to help the 3-4 pack survive...I do them all. A new product is almost ready to be put into my hands by the end of the month, the sonnax smart-shell input drum. No more snap ring and plenty more clutches plus the ability to run stupid line pressure and not blow the snapring out of the input drum....
JUNK is offline   Reply With Quote
Old 04-26-2012, 06:35 PM   #5
TZ2884's Avatar
I'm looking at performabuilt now, no core charge and layaway are very appealing to me. The level 1 should fit my needs.
Tags
2004, 23, 34, 4l60, 4l60e, 4l65e, flare, flares, flaring, shift, slight, solenoid, spin, transmission, wot
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
