Need help starter is hitting flexplate th400 - LS1TECH
Automatic Transmission 4L60E | 4L80E | TH350 | TH400 | TH2004R | Powerglide | Converters | Shift Kits
Thread Tools Search this Thread
Old 04-25-2012, 07:14 PM   #1
Unhappy Need help starter is hitting flexplate th400
Guys need help bad pulled the motor out of the car 2 months ago due to spun rod bearing when I did found out I needed a new block so I bought a 2000 model ls1 block mine was 98 so I built it put it back in now the starter seems like it hits the flex plate when engaged Amy suggestions because before rebuild the car ran fine with the same setup it has bmr flexplate for ls1 to th 400 and a monster converter anything please help!!!!!
Dustys Svt is offline   Reply With Quote
Old 04-25-2012, 08:03 PM   #2
projectX's Avatar
Did you measure the distance between the two? Sounds like it needs to be shimmed.
projectX is offline   Reply With Quote
Old 04-25-2012, 10:36 PM   #3
That's kinda what I was thinking but everybody said you shouldn't ever shim the starters on these cars!
Old 04-26-2012, 03:09 PM   #4
projectX's Avatar
Quote:
Never heard that before. I just did my flexplate and 4l60e and it states right on the instructions to make sure it is within .010-.020 - measured mine and it was .020 so didn't need to shim.
Old 04-26-2012, 09:28 PM   #5
What does I measure the starter to flexplate?
Old 04-26-2012, 11:27 PM   #6
projectX's Avatar
Your measuring top to bottom distance between teeth.
Related Topics
Thread Thread Starter Forum Replies Last Post
Starter/flexplate alignment turbodarryl Conversions & Hybrids 10 02-06-2017 01:23 PM
5.3/th400/6.0 flexplate starter options? Serioussn95 Conversions & Hybrids 1 05-06-2014 10:36 PM
Starters dont fit after 700 r4 install on LS1 C4 LS1 Generation III External Engine 1 12-03-2012 10:10 PM
LS1 to Turbo 400 DTPerformance Automatic Transmission 11 09-30-2009 12:41 AM
installing starter - am i missing something?? demonpixel Generation III External Engine 9 08-24-2009 09:15 AM
Tags
400, car, distance, drill, flexplate, frost, hitting, instruction, kit, ls1, running, shims, starter, th400, trans, tuned
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
