Trans Brake Switch Location - LS1TECH
Automatic Transmission 4L60E | 4L80E | TH350 | TH400 | TH2004R | Powerglide | Converters | Shift Kits
Thread Tools Search this Thread
Old 04-29-2012, 07:27 PM   #1
Default Trans Brake Switch Location
Where and how do you guys mount your trans brake switches? Did you keep the stock steering wheel or go aftermarket? Post photos if you care to share!
Another question! If the car is in forward motion and you accidentally hit the switch are you going to destroy the transmission and/or crash your as the car locks up?
Joe
StraightTimeStirrups is offline   Reply With Quote
Old 04-29-2012, 09:12 PM   #2
i have mine on the steering wheel just so that when you launch it just feels more natural to me, the only pain in the butt is backing up. i knew a guy you wired in parallel a second button on the center console of a vega so he would turn around he could put his right hand on it and look backward.
if you hit it accidentally you can.... i had a customer with a c-4 hit the button at the 60ft mark accidentally and snapped the stator support tube off the front of the trans. And i had another one who ran a glide that accidentally hit it when he rolled in the water box, didn't hurt the trans but rolled over the sprag in the converter so it had no stall to it. easiest way to avoid in a street strip is put an arming swith somewhere
WPTransmission is offline   Reply With Quote
Old 04-29-2012, 10:12 PM   #3
Thanks! I like the idea of an arming switch!
Related Topics
Thread Thread Starter Forum Replies Last Post
TCC / Brake switch ? BBButch Automatic Transmission 3 05-25-2016 03:35 PM
Hobbs switch location? 2002 transam Patsy57 Fueling & Injection 4 05-02-2016 04:51 PM
tci brake line lockl switch sold horse,bought ss Suspension & Brakes 0 12-21-2014 09:03 PM
post up your switch panels on your race car midwestjunk Drag Racing Tech 15 11-28-2011 01:25 PM
DBW cruise control garys 68 Conversions & Hybrids 7 12-09-2010 01:23 PM
Tags
400, brake, button, converter, fit, nuetral, putting, remove, steering, switches, swith, trans, transbrake, turbo, vega, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
