Late 1-2 shift part throttle
Old 05-05-2012, 09:31 AM
pajamasam's Avatar
Default Late 1-2 shift part throttle
Hi, I just rebuilt my own 4l60e transmission and put it in with my freshly rebuilt motor. It has 3000 midwest converter but it is a pretty loose converter.
So i did my first startup and all that fun stuff, then i took it around the block. The 1-2 shift is really late like 3500-4000 Rpm but the shift feels normal and good when it does. All the other gears work great and normal.
It feels like its being commanded late.
Im gonna scan it(hptuners) later today see if i find anything.
Any ideas?
Old 05-05-2012, 01:08 PM
zracer323's Avatar
Shifts are commanded by RPM and MPH. I would suggest letting RPM determine the shift, then set the corresponding MPH about 3-4 lower than that.
Old 05-05-2012, 08:33 PM
pajamasam's Avatar
I lied i dont have 2nd gear, It goes from 1 to 3. It does have 4th gear so im going to look into the 1-2 servo piston seal and some other stuff.
Old 05-06-2012, 08:46 PM
Moderator
mrvedit's Avatar
That is only true for WOT shifts; I think pajamasam was referring to partial throttle shifts.
Partial throttle shifts are commanded only by mph. There is a tunable value that determines what percentage (%) of throttle is considered WOT after which shifts occur when BOTH the tuned RPM and MPH are exceeded.
(Sorry, not trying to correct anyone.)
Old 05-06-2012, 08:53 PM
Moderator
mrvedit's Avatar
Are you sure you are shifting from 1 directly to 3?
And are not just experiencing a loose converter?
I'm no trans expert, but if it really is shifting from 1 to 3, this sounds more like a shift solenoid problem. If the 1-2 servo wasn't working, I think (but not sure) that you would have a terrible flare after shifting out of 1.
(Again, they is way out of my experience level.)
Old 05-11-2012, 09:32 AM
pajamasam's Avatar
FIX:1-2 shift servo piston had a cut ring, replaced and works great.
onto the next problem.
Quick Reply: Late 1-2 shift part throttle
