4l80e swap codes
Old 05-17-2012, 07:59 PM
Shinn98ls1's Avatar
Default 4l80e swap codes
Put in a 99 PCM in a 98 trans am, did a repin of the harness, did a 4l80e swap out of a 2000 2500hd with 105k, getting codes p0748 an p0758,!the car takes off in second an will not shift to first, or will it shift to first manually........ Any IDEAS!!!!!
Old 05-18-2012, 09:00 AM
Shinn98ls1's Avatar
Bump....Need help!! How can I check if the transmission segment was swapped correctly? What should I should be checking?
Old 05-18-2012, 10:07 AM
joecar's Avatar
1999 PCM out of what vehicle...?
Old 05-18-2012, 10:08 AM
joecar's Avatar
You will have to double check your pinouts.
BTW: Did you repin the TCC PWM signal...?
Old 05-18-2012, 12:36 PM
Shinn98ls1's Avatar
I have double checked all the pinouts. What is PWM?
Old 05-18-2012, 04:33 PM
joecar's Avatar
Old 05-19-2012, 09:55 PM
Shinn98ls1's Avatar
99 1500 4.8/auto
Old 05-20-2012, 11:32 PM
joecar's Avatar
Originally Posted by Shinn98ls1
99 1500 4.8/auto
I don't know my trucks too well, I assume it had a 4L60E, right...?
Old 05-20-2012, 11:34 PM
joecar's Avatar
Even if you do the trans segment swap you have to move the pin for the TCC PWM signal at the trans connector.
Old 05-21-2012, 10:40 AM
onebaddmax's Avatar
This is a buddy of the OP. He bought the wiring adaptor from speartech that was plug and play. Is this still needed to swap the pinouts at the trans?
Old 05-21-2012, 11:54 AM
onebaddmax's Avatar
Yes, the new PCM came from a 1999 1500 4.8/4L60e
Old 05-21-2012, 02:24 PM
joecar's Avatar
If the harness is for 4L80E then is should already be ok.
Old 05-21-2012, 09:20 PM
onebaddmax's Avatar
Any other ideas?
Old 05-21-2012, 09:53 PM
joecar's Avatar
You will have to check the harness by checking continuity between the PCM connector(s) and the trans connector to make sure it is wired right... you will need wiring diagrams for PCM used on a 4L80E platform and for 4L80E trans connector also.
Old 05-22-2012, 05:46 AM
onebaddmax's Avatar
Will do that this evening. Thanks
Old 05-22-2012, 08:45 PM
onebaddmax's Avatar
Problem solved. Turned out to be when one of our other buddies helped us throw the trans in he had plugged in the connector upside down. Too many cooks in the kitchen.....but on a side note, this thing whines loud in first gear and from what I read it's normal, but why?
Old 01-01-2014, 09:20 AM
vwdave's Avatar
I dont like playing thread jesus and rezzing the dead, but mine was the same exact problem. My connector on the trans is cracked and allowed the plug to go in backwards. Thanks for the update, saved me a bunch of time.
Old 03-28-2014, 09:48 AM
WS6HUMMER's Avatar
Which plug was it that was upside down? I'm dealing with the same exact issue and REALLY hope this is all it is.
Old 03-28-2014, 12:28 PM
vwdave's Avatar
The main round connector on the drivers side.
Old 03-28-2014, 01:12 PM
WS6HUMMER's Avatar
Thanks, I assumed that and gave it a shot & it fixed my problem too. Thank goodness for this thread!
Quick Reply: 4l80e swap codes
