TH350 with VSS
Old 05-23-2012, 10:43 AM
the_merv's Avatar
Default TH350 with VSS
I know there is a kit out there, but I decided to go a little out of the box with this one..
This will only work with the TH350 Longtail (9").
I got ahold of the Fitzall Spacer, part # 7Q-35B, it comes with the Spacer, Bolts, and other small pieces. Then I also got a 4-bolt 4L60E Tail Housing with small VSS..
Pictured in there also is the stock TH350 9" Tail Housing.
On the stock Output Shaft there is a bevel, I grinded that down and after some precision Dremeling I splined it and installed a T56 17x Reluctor Wheel..
Measurement from center of the VSS to the end of the Tail Housing with Spacer came out to appx 3 13/16". I installed the Reluctor with the center very close to that.
I then bolted up the Tailhousing and checked VSS clearance..
I had to Dremel down the flange on the VSS to get it within .005" of the Reluctor so it picks up the pulse. I then updated the Tune of the car to adjust for the new Reluctor Setup. Pretty much the same as a T56 car now.
So far everything works and checks out on the Transmission, and it's about $110 invested to make this work. It saves the hassle of removing the Trans and tearing it down to install the other kit.
Old 05-23-2012, 08:39 PM
the_merv's Avatar
I have the speedo fully calibrated with the laptop, works flawless.
Old 04-18-2013, 11:35 PM
the_merv's Avatar
Bumping this one up..
Old 04-18-2013, 11:49 PM
MillsMotorvation's Avatar
Dang I have short tail . I had the Dakota Digital but it fell out got mangled. time for a new one . Great work on your setup.
Old 04-21-2013, 11:37 AM
pricesgarage's Avatar
i ve used a 700r4 or 4l60e reluctor wheel and a buick olds pontiac extention housing the speed sensor fit perfect
Old 05-15-2013, 12:15 AM
How do you get the wheel off, will it just slide off if you tap on it? I saw some in junk yard today, but the teeth were a lot closer together, do they need to be a certain amount of teeth on the wheel?
Old 05-17-2013, 10:53 PM
7beast's Avatar
Looks good man, i have a short tail but have a long tail as spare. Might do this.one day
Old 08-27-2013, 12:41 AM
the_merv's Avatar
That's an extra one from the T56's I rebuild..just set the Tune in the PCM up for it.
Old 08-27-2013, 12:57 AM
Jake's Performance's Avatar
Necessity is the mother of invention...
A 4L60E reluctor should press fit on the 350 shaft, so I would HIGHLY suggest not butchering the output shaft like that. It makes it weaker.
Old 08-27-2013, 01:41 AM
the_merv's Avatar
Didnt have one available..so I improvised.
If I break that thing then I'm doing something right.
Quick Reply: TH350 with VSS
