A4 700r4(4l60) questions
Old 05-26-2012, 07:54 PM
pearlpurple's Avatar
Default A4 700r4(4l60) questions
Just bought a motor and tranny
93 Fbody is what is came out of and it is for my 93Z28 (eventually)
Quick questions:
1) I know my tranny in my car and the one I just bought (non electronic) has the TV cable to the throttle body, the 4l60E (electronic) does not right?
2) The speed sensor/and plug on the non electronic is different than the 4l60E right?
3) The plug for the hook up is a five pin round plug on the transmission that I bought this is different than the 4l60e as in what does that plug look like for the 4l60E (electronic)?
Thanks for any help.
Old 05-26-2012, 08:18 PM
whytryz28's Avatar
If you're putting a 93 trans in a 93 car it will all hook up directly.
The 4l60e has a 4 pin plug iirc
Old 05-26-2012, 08:47 PM
Thanks fo rthat but,
I know that if I bought a 93 it will fit a 93,,,,, the questions I ask are to verify that I have the correct transmission and that the seller did not send me the worng thing saying it was the right one,,,
The electronic (4L60E) transmission does not have a wire cable that goes from the transmission to the throttle body where as the non electronic one (700R3 / 4L60) does correct??
Old 05-26-2012, 09:38 PM
whytryz28's Avatar
Yes the 4l60e has no TV cable, its plugged. The 5 pin connector is another way of knowing its a 700r4.
Old 05-26-2012, 10:00 PM
lt1-xjs's Avatar
The '93 4l60 has a 5 pin connector, the prior 700r4 has a 4 pin connector.
Old 05-27-2012, 05:07 AM
Thanks for the help guys now I can take the tranny to the shop and a get it rebuilt
Quick Reply: A4 700r4(4l60) questions
