4l65e in a 2000 z28???
Old 05-30-2012, 01:04 PM
00zcamarols1's Avatar
Default 4l65e in a 2000 z28???
I called up the company I'm ordering my new tranny from and they said I needed a 4l65e?? I thought the ls1 camaros had the 4l60e?
Old 05-30-2012, 03:03 PM
WRT
WRT's Avatar
You have a 4l60E.
Does it have the top bolt hole?
Old 05-30-2012, 03:25 PM
mjs1012's Avatar
who did you call? and yes our cars have the 60e stock
Old 05-30-2012, 04:50 PM
Moderator
mrvedit's Avatar
Yes, WHO did you call? They gave you incorrect info.
Old 05-30-2012, 11:24 PM
I called Monster trans.
Old 05-31-2012, 08:35 AM
Moderator
mrvedit's Avatar
Some people (even builders) are mixing up the '98 and later 4L60E which has the bellhousing hole at the 12 O'Clock position with the 4L65E which came out in 2002 with stronger internals but IDENTICAL outside appearance. Many of the better transmissions from most builders could be considered 4L65E because of their internals.
The 12 O'clock hole is not just for mounting the trans, (from the factory) it also indicates a 300mm input shaft which is needed for LS engine compatible torque converters.
