How do you adjust the transmission shift modulator valve for BOP turbo 350?!
I have an 80 trans am with a BOP turbo 350 tranny and I need help on how to adjust the transmission shift Modulator Valve. Can I adjust the stock one? And then if you can, can you guys tell me how to do it maybe some pictures??
It has to be an adjustable type first ! If it is , the vacuum port on it will have a screwdiver slot . You turn it in for more pressure or out for less , 2 turns is about all you shoud do !
