02 silverado 4wd 4l60e shift problem
Ok so what is happening is on the 2-3 shift it kinda feels like it is shifting twice to hit the same gear, RPM drop and everything 'but not much".But u can feel it. Also occasionaly it happens from 1-2 but has only done it a few times,When it is in gear it drives normally and all other gears are normal.This started happening about a month ago.
Checked fluid, RED, and smells "used" maybe slightly burnt
Doesnt matter throttle position, low throttle or WOT (changed TPS)
Put on a Tech 2 (no codes)
Checked solenoid and servo function( seem normal )
Fluid was changed by a dealer before i bought it 1 yr ago (7k miles ago)
