broken tail shaft 4l60e
to answer your question i believe that any fbody tailshaft housing should work seeing as they are all the same.
93-95 F-body tailhousings are interchangeable within those respective years. 96-97 are also interchangeable within each other, and 98-02 are also interchangeable within those years. So to break it down for you, there are kind of 3 different generations of the F-body tailshaft housing for the 4L60e.
After replacing the tailshaft housing you might want to install an aftermarket torque arm that has its own crossmember!! Spohn, BMR, UMI all have quality parts to prevent this from happening again. I'm using a Spohn chassis mount ta along with their lcas, phb and sfcs. Good luck with the repair and hope this helps!! Larry.
thanks for all the help i forgot to tag this so i didnt know anyone answered so i asked the question again but in a different way sorry guys that i didnt reply to this thread. I got some good answers from the other as well. I cracked the tailshaft houseing rite under the TA mount, no I was useing the stock rubber mount. I'm going to find what ever i can camaro firebird s10 etc doesnt matter i'm getting a crossmemer mount from someone, not sure what company yet. again sorry ans thank you
AfterI broke my Tail shaft housing. I upgraded the Torque arm to an adjustable Umi TA and relocating bracket but I also got the LCA's and Panhard bar too just to have everything right. Tail shaft housing's can run you anywhere from 40-100, good luck and remember to replace the bearing in the Tsh, I didn't replace mine and it is going and I will have to pull the housing again hahaha weak.
