TCC Brake Switch.
TCC Brake Switch.
I just got done with my T-56 to auto swap, I used a Speartech harness for the conversion with my stock 6spd engine harness. I wired it just like in the sticky,
A. Shift Lock control circuit - Black/white wire from shiftlock control solenoid (Connector C200, Pin E)
B. PCM - Orange/Black wire from the white connector (Connector C220, pin H)on the end of the engine harness (the one that is inside the car on the passenger side under the kick panel)
C. Back up Lights - Brown wire, Same connector as above (Connector C220, Pin G)
D. Ground - Light green wire in Connector C400, Pin F (not sure where this one is but I can look it up) or to a chassis ground.
E. Start circuit - Clutch override switch (on the pedal), Purple/white wire
F. Start Circuit - Clutch Override switch (on the pedal), Dark green wire
Except I had to run the reverse switch wires to the pnp switch to get the lights to work because I have the t56 engine harness still. Now my question is everything works great except the converter seems to be unlocking everytime I let off the gas, do I need to wire the TCC brake switch manually to pin 33 in the PCM? Whats the best way of doing this?
tcc wire from ecu
I got a 71 camaro with a 4L60E with no cruise .so can I just hook my tcc wire up to brake switch without running a relay ?
Also does it need full 12 v all the time or just with the pedal pushed.
Thanks for any help.
I don't know what brake switch you are using, but you should be using one from a late model car that uses TCC. I would not think you would need a relay, just a fused 12v with key on and a brake switch that is closed with pedal up and open with pedal depressed. I attached some wiring diagrams that may help.
