Break-in time?
Break-in time?
Hi LS1Tech.
I will soon make a tranny swap to a new rebuild Lvl 2 4L60.
Everything is set and ready, but then I wonder if there is som kind of break-in time, or break-in milage you have to do on a new rebuild tranny, before you step hard on pedal?
Thanx
BoxeDK
Thanx
BoxeDK
Drive it easy for a while. Yank suggests 150-300 miles depending on their model you buy. Just drive it normal so that it gets used to usual load before going WOT and whatnot.
Thanx.. Another question:
The bellhousing bolts, and TC bolt, is it a good idea to add som loctite or is it unnecessary ?
Maybe the loctite will show the torque before it's really reached? Just a thought...
I'm pretty sure you'll want loctite on them. Bolts coming out from those areas are not a good thing. I would suggest the blue loctite so they can be removed but will stay in place otherwise. I'll let others chime in though, I haven't actually done it yet myself, I've been researching for a long time though.
