tans wont take gear. Whats Wrong!
Old 06-26-2012, 08:18 PM
OutrunNAScaR14's Avatar
Default tans wont take gear. Whats Wrong!
So i was pulling my 2001 trans am out of the shop and i was having to back up and pull forward in small amounts to get out. I did this 5 or 6 times and had no trouble. Then i was going from drive to reverse and and nothing was there. the transmisson wont pull in drive or reverse and wont hold inself in park. What happened? i checked the shifter cable and it seemed to still be work, what else could it be?
Old 06-26-2012, 09:42 PM
joecar's Avatar
Did you check fluid level...?
Old 06-26-2012, 10:19 PM
Yes fluid is fine. It just confuses me bc it was pulling fine and then it went to nothing
Old 06-26-2012, 10:21 PM
MIKEY'S 2002 TA's Avatar
Default trans
its probably the pump.
Old 06-26-2012, 10:42 PM
What pump
Old 06-27-2012, 09:58 AM
72blownvert's Avatar
Check the linkage first. Sometimes the plastic grommit falls apart and comes off the arm on trans.Even if it had a bad pump it would still hold park.
Old 08-05-2012, 12:49 PM
Justin_2000z28's Avatar
check the converter..
Old 08-05-2012, 01:01 PM
LS1Tech Sponsor
performabuilt's Avatar
If it wont move or hold itself in park I would suspect a linkage internal or external issue as the other other thing would be the rear end that could cause what you are describing the wont hold in park being key.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
