Ok. My budget only allows me to use my TH400 with my 5.3 swap...
Someone please help me out with what I would need to with use my TH400 behind my 5.3/6.0L swap... I have an LS swap book, but it doesnt mention the 400 much.. I know I will need an adapter to go on the flywheel is? (I read something like that a while ago but cant find it now.. What else will I need in order to make it work.. I have a 70 chevelle... my TH400 is already installed in it with a trans brake and shift kit.
What would I need in order to make the fuel injected LSx work.. By the way, I am going to turbo it along with the initial swap.. Just in case that matters...
Along with a 92MM TB, ls6 intake, LS6 or Z06 cam, LS6 or Z06 springs, and 243 heads... This is the plan.... I had to skimp on the xmission because I have a perfectly fresh rebuilt one in it now....
