Improper downshift above 50mph?
Old 06-28-2012, 11:27 AM
Torquewrench87's Avatar
Default Improper downshift above 50mph?
Car is stock 2001 trans-am with a 4l60e. The problem is when im going above 50mph and jab the gas (wot) it does not seem to downshift enough rpms only jump to 2,500rpm. but if im doing below 50mph it does perfect downshifts.
Heres a vid of what its doing remember it only does this above 50mph and this is wot pedal to the floor.
http://youtu.be/tEdhaLGbzXc
Old 06-28-2012, 01:11 PM
ramairetransam's Avatar
its ruined . Not sure it will rev to 6k from a dead stop ?
Old 06-28-2012, 01:56 PM
Ya like i said everything is perfect before 50mph it will redline if you do the same at any speed lower then 50mph
Old 06-29-2012, 10:26 AM
anyone? maybe a pcm reset? think it would help?
Old 06-29-2012, 10:34 AM
It's worth a shot. Try it. Also have you checked the fluid level. All connectors plugged into the Trans. And try the reset first
Old 06-29-2012, 12:25 PM
plugs are fine so is fluid. gunna reset it here in a bit. thanks
