2-3 Shift Solenoid....
Old 04-01-2004, 02:50 PM
Z'mnypit's Avatar
Default 2-3 Shift Solenoid....
Im in the process of installing a new 2-3 shift solenoid, & I wanted to double check myself... If im not mistaken isnt the solenoid on the passanger side the 2-3 shift solenoid?
Old 04-01-2004, 10:07 PM
LS1NOVA's Avatar
yes, that would be correct, just did one today in a Bravada.
Old 04-02-2004, 07:48 AM
Z'mnypit's Avatar
Thanks, I replaced and everything is PERFECT now............
Old 04-02-2004, 09:42 AM
boseman350's Avatar
how hard is it to replace these selanoids ??? can i do it in my garage on stands ?? ive already blown 1-2 and 2-3 shift selenoid so incase it happens again i want to sacew some money. thanks
Old 04-03-2004, 09:40 AM
LS1NOVA's Avatar
Yes you can do it. Just remove the pan and on the rear of the valve body the solenoids can be replaced by removing the clips with a pick. Be sure to lube up the new seals with some trans fluid.
Old 04-03-2004, 05:55 PM
Z'mnypit's Avatar
yeah LS1Nova hit it right on the money.... I did mine on jack stands, it took about 30 min... Its very simple the most time consuming part is taking all the bolts out of the trans. pan... PINTA......
Old 04-03-2004, 06:03 PM
Cokeroker's Avatar
Default how can you tell?
how can you tell if you have blown one of the shift solenoids? I am A4 and it seems when I kick down while in the 3rd or 4th (I assume it is kicking down to 2nd when I hit the gas to WOT), it seems to punch, then lag out some times
suggestions?
Old 04-04-2004, 11:56 AM
boseman350's Avatar
yeah i owuld like to know when mine is going too ! sometimes my tranny jsut act wierd ! would a hanes manual help me replace them ?? or should i buy a 4l60 e tranny book >?
thanks
Old 04-04-2004, 03:30 PM
LS1NOVA's Avatar
Usually if these solenoids are failing they will also set a dtc. A lot of times, the valve body is at fault for causing weird shifting problems. If sediment get in the valves, it can hang it up one time and the next time could be just fine.
